Odd Idle on my 91Z
Old Jul 1, 2013 | 03:34 PM
67z28's Avatar
Car: 1991 Z28
Transmission: 5 Sp
Odd Idle on my 91Z
I've got a 91Z-5M that i recently removed the intake and cleaned everything up so it would look better. I did take the throttle body apart and put new gasket in it while I had it apart. When I got it back together I can crank the car and it idles as it should, but when I give it throttle it doesn't come all the way back down to normal idle. It stay maybe 500rpm higher. I can turn the car off and let it sit for a minute and restart the car and it idle like is should, but again soon as the throttle is raised the idle doesn't drop back to where it should be. I'm thinking the throttle position sensor my be bad?
One other question is my tach reads incorrectly all the time. I've heard an aftermarket coil could cause this. The person that owned the car prior to myself put an MSD coil on it, how do I calibrate the tach?
Ray
Old Jul 1, 2013 | 04:57 PM
CAMAR0kid93's Avatar
Car: 1987 Chevrolet Camaro Iroc-z
Engine: 305 CID Tuned Port Injection
Axle/Gears: 3.23:1
Re: Odd Idle on my 91Z
try unplugging your throttle position sensor and start the engine. it will throw an engine code but nothing bad will happen. I just had to do this today as well. If your idle doesnt get worse than i would say its the tps. theyre around $35 new
Old Jul 2, 2013 | 09:49 AM
67z28's Avatar
Car: 1991 Z28
Transmission: 5 Sp
The idle isn't bad it just doesn't come down to normal idle rpm
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
Jlanz55
Sep 6, 2015 07:28 PM
