TPI Plenum cleaning
Old Jun 3, 2013 | 12:52 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
TPI Plenum cleaning
On a stock TPI, what is best to clean grease and oil off of the plenum and runners?
Thanks,
Robin
Old Jun 3, 2013 | 01:03 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Plenum cleaning
Casteroil super clean
Old Jun 3, 2013 | 06:25 PM
ghost91's Avatar
Car: 1991 Camaro Z28
This stuff... http://www.nevrdull.com/
I used it on mine. It takes off baked on deposits and even shines it up a little. Came out nice for me. Just wear gloves when using it. Take a chunk of it, rub it on the area you are cleaning, let it sit for a couple of minutes then buff it with a microfiber towel. Done. The material, your hands and the towel will be black. Thats how you know its working. You can buy it in Wal Mart, Pep Boys, and stuff like that. Heres mine. Not too shiny and looks good.
Old Jun 3, 2013 | 10:10 PM
DirtyBird87's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7L TPI
That looks awesome ghost! I have some never dull so I will have to try that out. My plenum is filthy.
Old Jun 3, 2013 | 10:29 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Thanks,
Robin
Agreed Neverdull all the way.
Old Jun 4, 2013 | 10:37 AM
ghost91's Avatar
You can also give purple power degreaser a shot. That stuff is like magic. Then use the never dull after that
Old Jun 6, 2013 | 01:20 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
marked
thanks guys - TPI off, new motor going in, want to clean it up!
Old Jun 25, 2013 | 02:53 PM
jlacoste's Avatar
Car: 1987 IROC
I borrowed some industrial degreaser from work. I filled up a wash tub with it and left the plenum, risers and, lower intake soak for like 3 days then hit real quick with a pressure washer. The whole setup looks brand new and the hardest thing I had to do was pull start the pressure washer. It even cleaned out all of the ports and tubes.
Old Jun 26, 2013 | 12:32 PM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
I purchased the Neverdull specifically because it was recommended here. It didn't do much (if anything) on my plenum. Maybe because it wasn't that dirty to begin with?
Old Jun 26, 2013 | 01:05 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I wouldn't try this with the TPI stuff on the car, but I have a spare plenum I may try...
The Eagle One Aluminum Mag Wheel Cleaner is like magic on the turbo cast wheels...
Wo I'll try it on the plenum and see.... it's harsh stuff, though, so I don't know about it getting on any rubber parts...
Raf
Old Jun 30, 2013 | 08:51 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Neverdull didnt do anything for my plenum or runners, except get the top layer of dirt off. I had to glass bead my intake because it was so dirty. I may try the purple power degreaser on the runners and plenum.
Old Jul 1, 2013 | 03:21 PM
67z28's Avatar
Car: 1991 Z28
Transmission: 5 Sp
I bought a $20 hand held sand blaster from Harbor Freight and a container of glass beads. The intake came out looking near new when I was finished. I did this with the intake off the car. I did the upper, lower and intake runners.
Old Jul 1, 2013 | 08:47 PM
ghost91's Avatar
Not sure why you guys had no luck with the never dull. It shined up my runners like in my picture in my above post, and cleaned the plenum as well. Its not going to shine the plenum, but it will clean it off a bit. Good luck
Old Jul 2, 2013 | 11:15 AM
Camarobreaker's Avatar
Car: 1989 IROC-Z
I used a wire wheel to the outside and then welded a small wheel on a 12 inch metal rod to get the insides of the runners. The outside came off no problem, and the inside contained 3 handfulls of deposits that I cleaned out as well. Then after that I took one of those headlight restore kit buffer things that goes on the drill and went at it with brasso. As you can tell in the picture, a mirror finish this aint, but its waay cleaner than when I started. I could also spend a hour or two more polishing it once I get these oil leaks patched up. Shes shining bright tho! good luck to ya
MantyZ28
16
Dec 21, 2015 11:02 AM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
