Airbox gutting results?
Old Jul 2, 2013 | 03:51 PM
MattGibson1's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.0
Axle/Gears: stock
How's it going, I have been reading up on gutting airboxes and was wondering if there are actually any performance gains? Such as performance I can actually feel? I have been considering this because it is free and I'm a high school kid, so money is pretty tight. Any help would be greatly appreciated, thanks!
Old Jul 3, 2013 | 03:01 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Airbox gutting results?
I've noticed that my tires chirp more often during the 1st to 2nd gear shift during the winter when I drop the gas pedal.
Old Jul 5, 2013 | 02:28 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Worked for me- especially at higher speeds.
Old Jul 5, 2013 | 04:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is a thread here somewhere where a person went even further. He used a heat gun or a hair drier to soften the plastic and re-form it to make the passages larger. Claimed that it also helped.
A search may bring it up, I wish I recalled more about it for search terms.
RBob.
Old Jul 5, 2013 | 04:59 PM
RBob.
I dis see thread where a guy seperated the upper and lower section of the dual intake. He then added around .5" inbetween the upper and lower section of the dual snorkel housing. I don't recall the results. It's been around a year since I read the mod.
Old Jul 6, 2013 | 06:00 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
I gutted my air box and it helped a good bit. I later made a ram air intake that made a real difference. Both modifications are definitly worth it.
Old Jul 6, 2013 | 10:47 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
It's a free mod might as well. with airflow going stright though instead of going though baffles and mazes.
I noticed a difference.
Old Jul 7, 2013 | 01:15 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I did it years ago. I really haven't noticed any difference.
Old Jul 8, 2013 | 11:26 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I noticed a slight increase in pull but nothing to ride home about.. Hard to say if it's psychological or real world improvement.
Old Jul 8, 2013 | 11:47 AM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
Gutting the air boxes certainly won't hurt anything, but as far as performance goes, you probably won't notice a difference. With all the research I've done it seems that the base intake manifold is the biggest restriction in the fuel/air delivery. Until you upgrade that other mods (throttle body, runners, ect.) won't have a big effect on power.
Linson
Oct 24, 2025 02:00 PM
Falcon50
Aug 22, 2020 03:26 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
