hard initial startup and after driving for a while??
Old Jul 6, 2013 | 08:59 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Ok so I finally got the T/A up and going so its time to start on some of the little things left.
First thing in the morning or well just the first time I go to start my car the engine will just turn over and over and over till finally it'll start trying to run and will run fine once it starts.Also if I drive for a while and stop and turn the ignition off it will do the same thing except then itll almost act like the starters dragging just a little bit but not much,I have to let it sit for just a few minutes then it'll fire right up and run just fine
I can start it and let it run in the driveway for as long as I want and it'll start everytime I turn it off and start it again..Any ideas suggestions hints or tips?Thanks
Old Jul 9, 2013 | 05:04 PM
dwillis's Avatar
Axle/Gears: 3:08
Re: hard initial startup and after driving for a while??
no ideas?
Old Jul 9, 2013 | 05:07 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
What's your timing set at?
Old Jul 9, 2013 | 06:43 PM
dwillis's Avatar
Axle/Gears: 3:08
6 degrees BTDC like the shop manual suggest
Old Jul 9, 2013 | 10:37 PM
Engine: 5.7 TPI
What else have you done to it? I'm just trying to get on the same page as far as what could be the issue to try and isolate it. I don't know if you have an EGR valve, but I remember using the wrong type on a car and it struggled to turn over. That doesn't mean it's your issue, though. Just throwing out an idea. If you can, just make a list of some of the stuff you fixed/replaced.
Old Jul 10, 2013 | 01:37 AM
niGhTcrAwler1's Avatar
Checked fuel pressure?
Old Jul 10, 2013 | 06:47 AM
dwillis's Avatar
Axle/Gears: 3:08
egr has been deleted...heres a link to my previous thread of the trouble i was having
https://www.thirdgen.org/forums/tpi/...el-issues.html
Old Jul 10, 2013 | 06:55 AM
dwillis's Avatar
Axle/Gears: 3:08
heres a couple videos I did yesterday checking the fuel pressure while driving and then after I got back home in the second video.The second video is kinda long but but bout half way through it it releive the fuel pressure and it stsrts doing what it normally does.I guess it was just feeling good yesterday and didn't wanna act up.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mcquigg
Aug 13, 2015 02:26 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
