coil swap
Old Jul 7, 2013 | 02:12 PM
Modify Heavily's Avatar
Car: 1986 Trans Am
Engine: TPI 305 from '89 Formula Firebird
Transmission: T5 also from the '89 Formula
Axle/Gears: 270 pos
coil swap
Ok I am tired of searching and only finding the opposite of what I am looking for, somebody please help!! Here is the issue, I have the TPI engine out of an '89 Formula firebird. I want to keep the tune port system but NOT the external coil. I want to swap to an in cap coil instead. My concern is with wiring it up in place of the external coil and also with the computer. Will it turn on the engine light if I do this? Also, does anybody know where I can get the spring kit for the distributor because the parts stores don't seem to carry them anymore or even know what I am talking about. Any help would be greatly appreciated.
Old Jul 7, 2013 | 02:26 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: coil swap
You will need to use a hei large cap from a 85-86 tpi in a f-body or 85-91 corvette or Ccc. This is a electronic controlled distributor with coil in cap and does not use advance springs like a vacuum advance distributor. You will also need to change the icm connecter and distributor power and tach signal lead if applicable.
Old Jul 8, 2013 | 01:41 AM
Car: 1986 Trans Am
Axle/Gears: 270 pos
Re: coil swap
Thanks for the reply, do you know if I can accomplish this without the engine light coming on or am I going to have to stick with the external coil to keep it from coming on? Also, how much performance would I sacrifice if I did just leave the external coil?
Old Jul 8, 2013 | 01:57 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: coil swap
If you're looking to do this as a performance upgrade, I'm thinkin' you're spending a lot of effort for literally no difference. A divorced coil might even be a hair better as it's hanging out in the open, maybe running a bit cooler.
Old Jul 8, 2013 | 08:08 AM
Engine: Lb9
Transmission: M20
Re: coil swap
just match the wire colors off the icm , DRP high, DRP, low, est, ground.
The spark Latency is different between the different icms but it will work fine without being reprogramed. bolth coils will output 40-50kv.
Old Aug 5, 2013 | 02:53 AM
Car: 1986 Trans Am
Axle/Gears: 270 pos
Re: coil swap
Thanks to everyone who responded to my question, but I have decided to stick with the factory external coil type and simply upgrade it to a street fire or blaster coil.
Fast355
Dec 2, 2016 06:33 PM
lt1z350
Aug 28, 2015 05:57 AM
TheExaminer
Aug 25, 2015 07:34 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
cstrobel65
Aug 15, 2015 10:19 AM
