Odd miss
Old Jul 19, 2013 | 11:23 PM
newagereject's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: 3.73 posi
Odd miss
When I make a corner my trans am will miss badly usually when i make a left hand turn around a round about or a right turn into my neighborhood it will miss and stumble hard until I pull out of the turn and go straight. Its gotten progressively worse over the last month to where it has killed on me while making a turn.
It happens if my take is full or almost empty, although it is somewhat worse when empty, my dad thinks that it could be the fuel filter i'm not sure if it is. Does anyone have any ideas what it could be?
Old Jul 20, 2013 | 01:37 PM
lethaldomestics's Avatar
Re: Odd miss
happens on my 87 bird 305 tpi. Usually when fuel gauge is reading low. My fuel guage is a lil off to i have to have at least a 1/4 tank on gauge in order to make swift turns without missing or stalling. hope this helps
Old Jul 20, 2013 | 04:54 PM
Re: Odd miss
It happens if it is full or close empty
Old Jul 21, 2013 | 04:52 PM
Re: Odd miss
I just tested the injectors, and they were 16.2 cold and 17.2 hot, the fuel pressure on a cold start was around 52psi, i also replaced the fuel filter and the car seems to be running better but it still has a consistent miss when taking a corner somewhat hard
Old Jul 25, 2013 | 11:14 AM
Re: Odd miss
bump
Old Jul 25, 2013 | 01:38 PM
whitecomet's Avatar
Car: 1987 Pontiac Firebird formula 350
Engine: sbc 355 tpi
Axle/Gears: 3.27 posi 9 bolt b/w
Re: Odd miss
it sound like maybe you need a new fuel pump. could not be sucking up enough fuel, not as much as it needs anyways or fuel pump relay
Old Jul 25, 2013 | 04:31 PM
Re: Odd miss
I had thought about that as well but it smells likes it running rich, what sensors could be affecting that?
Old Jul 25, 2013 | 10:42 PM
Re: Odd miss
Tonight when i got home from work i parked the car in the garage and there was a high pitched noise coming from the back end after i shut the car off and it was still making the noise 10 minutes later
Old Jul 26, 2013 | 11:10 AM
Re: Odd miss
sound to me like a bad connection while taking turns killing the pump. If your pump stays on after you take the key out you need relay
Old Jul 26, 2013 | 01:15 PM
Re: Odd miss
Im starting to think it could be fuel pump related, is there any sensors though that could make it have a hard time starting rough idle, almost kill when I give it gas or have flat spots with no power when I accelerate?
Old Jul 26, 2013 | 01:48 PM
whitecomet's Avatar
Engine: sbc 355 tpi
Re: Odd miss
the MAF or speed density sensor, the air intake temp sensor maybe those 3 affect a lot cant really thing of any others but the relay thing wouldn’t b a bad idea either. you can check them by swapping the fuel relay to the fan relay right next to it an vise versa to where both are plugged in on different relays, if no occurring changes happen the i guess that’s not your problem, or both relays are shot.
Old Jul 26, 2013 | 04:43 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Re: Odd miss
You need a fuel pressure gauge to diagnose this. Get one that screws onto the fuel rail and tape it to your windshield.
Old Jul 26, 2013 | 06:15 PM
alloutriot808's Avatar
Car: 1991 Camaro Z28 (G92)
Transmission: 5 speed T5
Re: Odd miss
When I first got my car it ran rich and would miss. Firing order was wrong and I had a detache vacume line that connected to throttle body.
Old Jul 26, 2013 | 11:05 PM
Re: Odd miss
Im thinking ill replace the TPS i replaced the IAC last year but the tps ohmed out ok so i left it alone, is it safe to drive with the fuel pressure gauge attached to the fuel rail?
Mark_ZZ3
May 24, 2018 01:02 PM
Fireslash
Apr 11, 2016 06:43 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
