1.6 Roller Rockers on L98
Old Jul 20, 2013 | 11:57 AM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Do these cause any problems with the stock chip? My car is idling erratically and showing around 14 grams at idle. Appreciate feedback from those that have installed this mod.
Old Jul 20, 2013 | 12:36 PM
Guest
Guest
Posts: n/a
Re: 1.6 Roller Rockers on L98
Make sure all the bolts are trq-d to spec.
your vacuum should be 17-19/20"
-you have a vacuum leak
Old Jul 21, 2013 | 02:11 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I actually just put my comp 1.6 roller tip rockers on my 91 two days ago and all is well. Not a huge difference per say but it definitely runs much better. Throttle response is much improved and it goes through the revs much better. Took my cam from 202/207 @.50 .413/.428 to 205/210 @.50 .441/.457. So basically just a touch smaller than a stock LT1 cam.
Old Jul 21, 2013 | 02:39 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
So you did end up going with 1.6s? Good man!
Old Jul 21, 2013 | 03:37 AM
well I already had them sitting in a box from my ZZ5.0 build so I figured hell I might as well use them lol. I'm still planning on the ZZ4 cam swap when the funds allow.
Old Jul 21, 2013 | 09:07 AM
BadSS's Avatar
If it was OK before the swap,,, going to 1.6 rockers won't make much difference to vacuum or idle. Make sure the pushrods are not rubbing the pushrod hole - it shouldn't be. Then,, readjust the preload - I usually go 1/2 turn from zero on the stock type lifters. Sounds like you have them run down too much - too much preload won't let the valves totally seat and will cause a rough idle/low vacuum.
Old Jul 21, 2013 | 01:07 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
I agree with BadSS. That is exactly what happen to me when I installed mines.
Old Jul 21, 2013 | 01:26 PM
You go a 1/2 turn? I usually go 1/4 turn and all seems fine. I've heard some even go to 3/4 turn.
Old Jul 21, 2013 | 01:44 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I don't know if you're trying to fix your idle issue with new rocker arms but I would fix the idle issue first before doing anything else.
Old Jul 21, 2013 | 02:45 PM
MrPackstin's Avatar
Car: 1989 GTA
Pulled out the old vacuum gauges and both are messed up. One showed 5.5Hg laying inside the toolbox. Hooked up it was around 22 at idle. The other gauge is a lost cause.
Not trying to fix the idle with rocker arms...already an issue with the stock ones. Just wanting to make sure the additional air does not throw off the ECM. As RobertFrank indicated it is not really an issue apparently with his car. Went half-turn past 0 lash, but there is a slight tick on the driver's bank...?
Old Jul 21, 2013 | 04:55 PM
BadSS's Avatar
It depends on the lifter. If they're stock and have some miles on them,, I'll go 1/2 turn. If they're new with the good retainer clips I'll go 1/4 turn. The last few set of flat tappet hydraulics I've used and installed were the Pro Magnums with a recommended preload of .002 - .004",, which is a little less than 1/8 turn.
Old Jul 21, 2013 | 11:02 PM
Dakota W.'s Avatar
The correct way of doing it is getting the correct length pushrod for the new, bigger rockers, so it's centered on the valve and you don't bust valves.
FormulasOnly
Jul 23, 2018 08:47 AM
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
