rolling idle
Old Jul 21, 2013 | 05:33 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
rolling idle
my 86 tpi car will hunt for a idle speed ,up down up down .in gear at a light it will do this till it dies. if I shift to neutral it idles fine.any ideas? everything under the hood is new and set correctly
Old Jul 22, 2013 | 02:45 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: rolling idle
Do you have a scanner? Is there any check engine light? What is the TPS voltage set at?
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
Fronzizzle
Sep 8, 2015 12:10 PM
