what is my car pushing??
Old Jul 24, 2013 | 03:15 PM
SRF's Avatar
SRF
Car: 1987 Pontiac Firebird Trans-Am
Engine: 5.7 350 TPI
87 TA
89 Formula 350 TPI
Shift kit
Stall converter
Straight pipe with auto zone flowmaster muffler
Eldebrock heads
Not sure what the gears are but its a one wheel wonder
My goal is to get it to 300-350 bhp
I don't want to dyno it but I would like to have a rough idea..
Old Jul 25, 2013 | 02:18 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: what is my car pushing??
I'd guess you're somewhere around 270hp at the flywheel right now (figuring roughly 225hp stock). Converter will definitely hurt your rhwp numbers.
Sounds like it's time for a cam!
Old Jul 26, 2013 | 09:35 AM
SRF's Avatar
SRF
Engine: 5.7 350 TPI
Would a cam hurt my rearend? What would you assume the hp at the wheels are? 240 250?
Edit: what are other options besides a cam to reach my goal. Budget wise I have nothing so I'm going to start saving and most likely have it done during the winter season
Old Jul 26, 2013 | 12:39 PM
navy02ws6's Avatar
I really think you'd have to be pushing 350-400hp before a 10 bolt rear-end would give out in an automatic car, especially if you're not running drag radials or super sticky tires.
If you're at 270 at the crank, I'd guess probably around 200-210hp at the wheels with your setup.
Old Jul 26, 2013 | 04:39 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I broke a stock 9 bolt with a Procharger, 4.11 gears, and 315 drag radials. It's all about traction. My other 9 bolt held up to 100's of passes on slicks with my turbo 3.8L pushing 500HP. Running street tires with stock gears, you won't break it with under 400HP.
Old Jul 26, 2013 | 07:05 PM
SRF's Avatar
SRF
Engine: 5.7 350 TPI
What kind of gains woud I see from a cam? Is there anything else I can add that would increase hp under 1000?
Old Jul 27, 2013 | 08:06 AM
navy02ws6's Avatar
Cam is going to be by far your best bang for the buck, with maybe longtube headers right behind it. Every little bit helps (air foil, underdrive pulleys, throttle body, cold air intake, etc.), but cam and headers are going to be your best bets at this point since you already have heads.
Upgrading your TPI setup will help you once you have a cam, but that's when it starts getting pricey.
Old Jul 27, 2013 | 09:27 AM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
What exhaust manifolds? what does exhaust consist of to the muffler? Which heads, what chamber . valve size, rocker ratio? ? Have you ported your plenum? Cam will give you more HP, but you may lose torque down low that you feel. What is this car's intended purpose? Weekend Warrior? Strip car?, Daily Driver? that will help guide you.
Old Jul 27, 2013 | 11:14 AM
SRF's Avatar
SRF
Engine: 5.7 350 TPI
I never really considered getting a cold air. Lots of people tell me that it domesn't really add hp and is. Just more for show. Also I might have mistaken heads and headers since I didn't know there were twodifferent kinds. As of right now the car is my daily driver. When I got rid of my cat I did notice a loss of llow end torque. What should the next step be? I just want the car to be on par with the newer camaros firebirds and mustangs. And danclemts I have no idea about that information. Assume that everything is stock besides what I mentioned.
Old Jul 27, 2013 | 10:26 PM
danclemts's Avatar
So, You have Edelbrock headers? These are the tubes that bolt to the head and go down under the car (exhaust) if everything else is stock, read the performance basics on the front page. Start there
https://www.thirdgen.org/tpimod1
If your car is stock, probably pushing a little over 230 hp with your exhaust mods, unless motor has been rebuilt in last 50,000 miles, I think in 89, they were rated at 240 HP
https://www.thirdgen.org/1989-pontiac-firebird
Old Jul 28, 2013 | 12:16 PM
navy02ws6's Avatar
We definitely need to verify whether he has Edelbrock heads, or Edelbrock headERS. If it's just HEADERS, then we really are talking a lot closer to bone stock RWHP because of the stall converter and 20+ years of wear and tear.
Old Aug 2, 2013 | 03:19 PM
SRF's Avatar
SRF
Engine: 5.7 350 TPI
Yea I'm pretty sure there headers. I can see the pipes where the engine is and I think they connect to the exhaust. Besides a cam and intake what are other options to reach 300 hp?
Old Aug 3, 2013 | 11:02 AM
navy02ws6's Avatar
Heads will be almost necessary to reach that kind of power, unless you go with a monster cam. They're expensive though...IIRC, aluminum Edelbrocks are now up to roughly $1,400 for a pair.
Old Aug 3, 2013 | 08:05 PM
racerx520's Avatar
i looked up for replacement aluminum L98 corvette heads, those are about 1500 to 2000. there are a few internal upgrades that can be done if you're willing, just have to research on it. anything engine wise is going to be expensive, this is just an expensive hobby to be into. If you really want 350 hp for under 1000, maybe a stroker kit? or find a wrecked vette or camaro in the junkyard....might be able to get it for around 1000
RazorN8
Jan 7, 2022 11:44 AM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reborn756
Sep 4, 2015 03:42 AM
apie2546
Aug 10, 2015 05:43 PM
