280 cfm, is it possible out of tpi runners?
Car: 1989 pontiac firebird trans am GTA
Engine: TPI 350
Transmission: auto 700r4
Axle/Gears: borg warner 9 bolt and 3.27
im trying to see if I can find some runners that can flow 280 cfm, stock or ported, the heads I want to use would be 195cc afr heads, does anybody know what as&m runners fully ported flow?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: TPI 350
Re: 280 cfm, is it possible out of tpi runners?
it don't show asm runners but thanks
Engine: Lb9
Transmission: M20
Large Tube runners for the 1989 to 1992 Camaro, Firebird and Corvette. Have proven to increase torque by 30 ft/lb. and horsepower by 25 on stock 5.7L engine Flows 260 CFM per runner, Clear hard anodized finish, Includes gaskets and 4 bolts. Matches factory appearance, Polished runners are optional, please select polished when ordering.
taken form the as&m website....
Engine: TPI 350
[quote=Tuned Performance;5615412]Large Tube runners for the 1989 to 1992 Camaro, Firebird and Corvette. Have proven to increase torque by 30 ft/lb. and horsepower by 25 on stock 5.7L engine Flows 260 CFM per runner, Clear hard anodized finish, Includes gaskets and 4 bolts. Matches factory appearance, Polished runners are optional, please select polished when ordering.
taken form the as&m website....[/
ok is it possible to port them to 280 cfm?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/post...714-post9.html
What do you plan to use for a TPI manifold that will support that head flow?
Some reading
https://www.thirdgen.org/forums/tpi/...-manifold.html
Some reading
Engine: TPI 350
Some reading
Some reading
Engine: TPI 350
Car: 82 Z28
Transmission: T400
Kinda like running up a hill with your hand over your mouth if you are looking to get the best out of the AFR's
Try
http://www.firstfuelinjection.com/products.htm
http://forums.corvetteforum.com/1562829858-post8.html.
for FIRST intake on here ; plenty of info
Try
Engine: TPI 350
thanks man,
so they sell basically the whole top end for the tpi, and everything is matched together, do they have the egr port? and I read ur corvette forum that's amazing
so they sell basically the whole top end for the tpi, and everything is matched together, do they have the egr port? and I read ur corvette forum that's amazing Thread
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
