Valve cover bolts
Old Aug 16, 2013 | 08:05 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Valve cover bolts
So I got a set of factory torx valve cover bolts from another member on the board...
However, when I went to install them, they bottomed out with a good amount of space left between the head and the valve cover. When I compared them to the the ARP bolts that were in there, I noticed that the factory ones are a smidge longer. These aren't factory heads, they are Sportsman IIs.
Any ideas?
Old Aug 16, 2013 | 08:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Valve cover bolts
Originally Posted by actarnoff
Sportsman IIs.
they bottomed out with a good amount of space left they are Sportsman IIs.
Would appear the threaded bosses in the SP I heads are at a diferent height to the stock ones ?
What gasket are you using?
Old Aug 16, 2013 | 08:29 PM
actarnoff's Avatar
Engine: 355 TPI
I'm using Felpro gaskets with a bit of RTV.
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
