What can be removed or plugged off on my TPI intake?
Old Sep 9, 2013 | 09:25 AM
quick57's Avatar
What things can I remove or plug off on the TPI intake to clean up the looks (no emissions)?
I will not be running A/C, EGR, or heater hoses. The obvious items are to block off the EGR, and plug off the outlet in the front of the intake for the heater hose. Anything that cuts down on the # of hoses and harnesses will help me out.
Old Sep 10, 2013 | 02:07 PM
87irocZ28Crush's Avatar
Car: 1987 Iroc Z28
Re: What can be removed or plugged off on my TPI intake?
I am doing the same thing. Even removed the 9th injector. Now after doing all this what do you do with the tb coolant connections? What vac hoses need to be rehooked now that the egr valve and the egr solenoid are no longer there?
Old Sep 10, 2013 | 04:00 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
I'm thinking about doing the same thing on my 85 LB9 Iroc. I am getting a re programmed chip that deletes the cold start injector, but I'd like to remove the EGR too.
Let me know what you guys are doing and maybe we can get a good conglomerate together!
Old Sep 12, 2013 | 02:31 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
You can reprogram all this by yourself if you have the tuning software / equipment (no EGR, AIR, AC, 9th injector, etc.). 9th injector removal especially is a good idea.. one less leaky POS to worry about, with the 6E code you don't need that 9th injector in there to start the car.
Old Sep 13, 2013 | 06:45 PM
Jonesyfxr's Avatar
This whole computer thing is new to me. I'm young and still know how to set up dual points and dwell. Lol
This is my first computerized car, so everything is new to me. Heatzone25 is supposed to be making me a chip so I can eliminate the 9th injector and I think I'm getting rid of the EGR too. This car runs pretty now, but I know it needs work. I just did the complete cooling system, including high flow water pump, radiator, hoses and thermostat. I also stabbed in a transmission cooler while I was at it.
Old Sep 14, 2013 | 03:23 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by 87irocZ28Crush
what do you do with the tb coolant connections? ?
Run the heater line direct from the intake manifold to the heater core and delete the TB heating on the IAC housing
Old Sep 14, 2013 | 03:27 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If you have deleted everything all you need is vac from the intake to the fuel reg and to the HVAC / CC/ vac ball
as well as the large vac line from the TB to the canister purge
Typical TPI vac setup shown
Old Sep 14, 2013 | 04:16 AM
Jonesyfxr's Avatar
I just did the throttle body bypass on mine, since I was doing the water pump, thermostat and radiator anyway. Since there's no water control valve I bought the Lumina heater hose and put a plastic 90* fitting at the stock heater hose, which had to be cut just before the elbow. I'll post pictures tomorrow.
1992rs/ss
Jan 31, 2025 05:10 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
