Need to get a/c idle-up working on 88 TPI
Can someone help me determine why I can't get it to idle up when the a/c is turned on? I have hooked the 12 volt positive from the a/c alutch to terminal B8 on the 7165 ECM and it doesn't effect the idle at all. I don't knwo the history of the chip that is in the ECM but I can tell you the ECM is new. I have a Snapon Modis scanner but I do not have a vin number to plug in to communicate with it. I am open to all ideas as I would just like to get it working properly to keep it from stalling at stop signs and lights. Thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need to get a/c idle-up working on 88 TPI
Check The grey wire on D11 of the ecm to the fan pressure switch for continuity.The pressure switch for 86-88 is normally closed 89 is n/o . A quick check bye jumping a to b on the aldl and turning the key on the ecm will command on both fans.
I appreciate the advice on the fan control, no electric fans here though, I am trying to figure out how to tell the computer to tell the engine how to idle up when the a.c clutch engages and is on.
Engine: Lb9
Transmission: M20
Most $32b calibrations have a small rpm adder 50-100 rpm. if grounding d11 or putting power to b8 status input doesn't mover the target rpm the ecm is bad.
I kept thinking about your first suggestion of grounding D11. I will try that once I get home today, maybe it takes both that and the power input to B8 before it changes the idle. I had that same thought, that the ECM was bad, but I literally just bought a rebuilt one 2 days ago (granted it is a Cardone rebuilt one from Oreillys Auto) Hopefully it isn't bad straight out of the box, but I could waranty it hopefully. Here is another question, could someone have had the chip programed and taken the a/c signal off of the chip altogether?
Engine: Lb9
Transmission: M20
its hit or miss with Cardone, If the memcal silver sticker looks wrinkled or torn it would have more than likely have been reprogramed. The tpi mafs used a grab bag of eproms 50% of the time I have to solder on a new one when reprograming. I dont know why any one would want to program out the a/c rpm adder but who knows
The bad news is the D11 was already grounded so I am back at square one. I am trying to get a scantool working so I can see what the computer sees, perhaps I have an obvious sensor problem, or that is what i am hoping for at this point. I am going to clean the MAF sensor with some MAF sensor cleaner but that shouldn't provide the idle-up feature I am looking for but maybe the idle could compensate with a better reading MAF sensor. The injectors all ohmed out between 16.9 to 17.1 hopefully that is the right range. I need to search a little for values here in the site. The fuel pressure runs about 41-42 psi while running, 50 psi with fuel pressure regulator vacuum disconnected.
Sanjay
Aug 12, 2015 03:41 PM
BikeFarm
Aug 11, 2015 11:35 PM
db057
Aug 11, 2015 10:11 PM
