l31 cam in 305 tpi?
Old Nov 6, 2013 | 08:08 PM
esp68camaro's Avatar
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700-r4
Axle/Gears: 3.73 posi
l31 cam in 305 tpi?
Ok so i came close to selling my girl due to buying another car but decided not to.
So this my deal i do not want to put a 350 in her ive got a bbc inthe other car. I
just want to have a cheap rebuild for daily driving and some autocross.
. It has a 305 tpi with 416' cast heads and the peanut cam. ive got sone parts laying around like 1.5 roller tip rockers m/t valvecovers and a l31 cam and friend of mine is giving me some flat top 4 valve relief pistons.... i guess my question is the l31 cam a good up grade from the peanut cam?
Old Nov 6, 2013 | 09:15 PM
Chad85T/A's Avatar
Car: 85 T/A
Re: l31 cam in 305 tpi?
It'll be a little bit of an upgrade. I did the LT1 cam in my 305, which is just a little bigger than the L31 cam and it runs good. I also have 416 heads that I ported and the combo works really well.
Old Nov 6, 2013 | 10:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Not much of a upgrade
191/ 196 .414 /.442
Less duration and similar lift to the 305 cams
https://www.thirdgen.org/forums/post...611-post3.html
Old Nov 6, 2013 | 10:25 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
remember the L31 engine is pretty much a truck engine . good luck .
Old Nov 7, 2013 | 01:35 PM
Car: 86 iroc-z
Engine: 305 tpi
Prolly just c if i cant find a cheapo used lt1 cam somewhere then. Already spent close to a thousand on rear supension a year ago might as well spend alittle extra for used cam.
Old Nov 7, 2013 | 01:41 PM
Car: 86 iroc-z
Engine: 305 tpi
Lt1 Cam with flat top pistons will it work without ecm work? ..ive got a 86 iroc with maf.
Old Nov 7, 2013 | 01:44 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
I think the 86 is a flat taped motor. LT1 cams are roller cams. You need to retrofit your block.
Old Nov 7, 2013 | 03:43 PM
Car: 86 iroc-z
Engine: 305 tpi
305 i have is a roller block.
Old Nov 7, 2013 | 04:13 PM
Chad85T/A's Avatar
Car: 85 T/A
Mine is running fine on the factory tune, although I believe there will be a bit better fuel economy and a few more horses to be had with a tuned chip. Mine has shorty headers , full 3" mandrel pipe, ported heads ,intake manifold , runners, and plenum with a set of hyperutetic pistons and the LT1 cam.
Old Nov 8, 2013 | 12:09 PM
Car: 86 iroc-z
Engine: 305 tpi
Whats ur gas mileage like?
Old Nov 8, 2013 | 09:32 PM
Chad85T/A's Avatar
Car: 85 T/A
I haven't been on any long trips with it, but on its usual 10-20 mile trips it gets 22 usually.
Old Nov 9, 2013 | 10:55 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I put an LT1 cam in my L69, and it really woke it up. If the block you have did not have roller cam in it before, you will need a bunch of other stuff too ( Dogbones, holddown spider, pushrods, cam retainer, roller cam timing set, maybe self aligning rocker arms). ECM was fine with the change. MAF adjusted with no issues.
Old Nov 9, 2013 | 07:33 PM
Car: 86 iroc-z
Engine: 305 tpi
Nice...thats good to know i figured if it was gonna get bad gas might as well up grade to an lt1.....my block is a roller block and already has all those goodys in it .... ive tried to to look into other cams as a stock cast upgrade other then the lt1 cam any other suggestions ???
Old Nov 9, 2013 | 08:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by esp68camaro
. ive tried to to look into other cams as a upgrade other then the lt1 cam any other suggestions ???
What is your budget?
There are better cams out there but they cost $$$
The LT1 cam is a popular swap because it can be had for free or next to nothing
and it only costs your time and some gaskets to fit to a OEM roller block.
Old Nov 9, 2013 | 09:57 PM
Car: 86 iroc-z
Engine: 305 tpi
Well i went ahead and bought a lt1 cam decided to go withit because of $$$....anyways thanks everyone for ur help!
Old Nov 10, 2013 | 08:29 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I like the factory LT4 and ZZ4 cams, cheap, make great power and have good driveability.
Old Nov 10, 2013 | 09:15 AM
Car: 86 iroc-z
Engine: 305 tpi
I like the lt4 hotcam i was gonna use that with a l31 with 906 heads i have but i really would rather keep the 305
And use all these 305 parts i have lying around then spend a tone of money on a daily driver and use on auto cross.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
