need head help!!
Old Nov 12, 2013 | 01:09 AM
Cody Plocher's Avatar
need head help!!
Okay so I'm putting an 89 Tpi set up on a high nickel 010 block which is bored .060 over. When I had my machine work done (boring) I told him I was gonna run 305 heads. So he got dished pistons so the compression wouldn't be too high. And like an idiot I didn't think too much into it and now I feel like the 305 heads won't breath enough to feed the 350. But I don't want to run 350 heads because I have dished pistons so it would drop compression down. I'd like to be running like 9.5:1 to 9.8:1 compression. Can i have the 1.94, 1.5 valves put into the 305 heads to help with airflow? And if so what should that run me cost wise?
Old Nov 12, 2013 | 05:58 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need head help!!
https://www.thirdgen.org/forums/tech...formation.html
What are the casting # on the 305 heads ?
Plenty have used 305 heads on 350's
https://www.thirdgen.org/forums/tech...305-heads.html
https://www.thirdgen.org/forums/tech...sing-60cc.html
https://www.thirdgen.org/forums/tech...lly-tried.html
https://www.thirdgen.org/forums/tpi/...350-block.html
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/post...839-post2.html
You could buy Corvette 350 /ZZ4 alum heads that have the same 58cc chambers as your 305 heads, probably a better investment with more perf potential than spending $$$ on your heads?
Old Nov 12, 2013 | 08:01 AM
86redIROC's Avatar
Car: 1986 Iroc Z 28
Engine: 383
Transmission: 4L60
This head has 56cc chambers so your compression will be good. They flow 240cfm@ .500 lift.
http://www.trickflow.com/search.asp?...7&autoview=sku
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
