Add 5th gen maf into 3rd
Old Nov 19, 2013 | 04:47 PM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I see the newer 5th gen all use maf but I think they have readouts in ohms. Ours are voltage. But it is much simpler and reliable setup like sd.
Why can't we use this assuming it takes 5 or 12v signal and just calibrated 0-255 in hex to the size intake and convert the drop in resistance to temp to cfm and scale it to the same maf input
Really any sensor that will read velocity pressure in volts output would work
Anyone try it? They are much cheaper. And readily available and unlike the sd mod I think u just reuse the existing wire harness for the maf since it has 12v for power and 5v input for signal and ground?
And to even calibrate further u could use the iat to further dial in the flow rate
Old Nov 23, 2013 | 05:55 PM
tequilaboy's Avatar
Re: Add 5th gen maf into 3rd
A modern digital MAF could be made to work, but would require use of a translator. This adds extra cost and complexity and at least some loss of signal quality in the conversion process. I prefer an analog MAF in this application since it is a simpler and cleaner solution. Programming changes are required for either method.
Old Nov 24, 2013 | 06:04 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Obd2 swaps can allow that. Cost me under $1000 to do it. I use the maf from a 2001 Silverado. Look up 411 pcm swap
chazman
Aug 28, 2018 03:25 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
Warlocksirix
Sep 3, 2015 12:26 PM
tricky1
Aug 23, 2015 01:17 PM
chazman
Aug 22, 2015 02:01 PM
