external fuel pump for TPI
Old Nov 19, 2013 | 05:21 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
I want to use an external fuel pump on my 91 Z28 with TPI anyone have any recommendations on what one to use.
Old Nov 19, 2013 | 07:11 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: external fuel pump for TPI
I can't recommend an external high pressure pump...but have to ask a few things
Is your in tank pump dead?
If so...pretty sure it's a positive displacement pump...can an external pump draw through it?
If so, please don't relie on barbed fittings and hose clamps, cut/double invert flare, and make good solid connections with your new pump...you only want to do this once...I can't see running a 60+ PSI pump spliced with rubber fuel lines and hose clamped to a cut steel line..being very reliable.
But back to my first point...if we can't suck though the original pump and it has to be removed and modify the pump insert...may as just as well put in another in tank pump that will last another 20+ years
Old Nov 19, 2013 | 07:29 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
The car is completely striped stock pump is gone I am putting a tank sump on it and using an fittings.
I know someone has done this.
Old Nov 20, 2013 | 12:18 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tech...-location.html
https://www.thirdgen.org/forums/carb...-mounting.html
https://www.thirdgen.org/forums/orga...fuel-pump.html
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
