Electric fuel pump mounting????
Old Mar 15, 2004 | 06:28 PM
topdog's Avatar
Car: 1986 Camaro Z28
Engine: 383 with Edelbrock Performer RPM
Transmission: Rebuilt 700R4
Where have you guys mounted the fuel pump?? I mounted mine between the pan hard bar and the rear end and it was a real pain. I used an aluminum bracket (weight..lol) but there was too much flex and the pump got hung up on the pan hard bar.
Any suggestions????
I'm planning on just changing to steel to mount it in the same location...
Any help would be appreciated....
Old Mar 15, 2004 | 11:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i mounted mine on the spare tire well. it's a straight shot from my sumped gas tank to the filter(mounted on the rear well) then over to the spare tire indent well for the fuel pump. works well for me.
Old Mar 22, 2004 | 06:19 PM
topdog's Avatar
Thanks for the info...
I'm still using the stock tank although I don't know if I'll keep it or not. It doesn't look like I have any room except on the frame beside the exhaust (something I'm trying to avoid). Here is a picture of the location....
Old Mar 23, 2004 | 10:28 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
That looks dangerous..too close to moving parts for my comfort.Bottoming out could cause a problem looking at that pic.Put it behind the driver side rear seat.Make sure it is level and you are good to go.My Holley black pump has been that way for four years now without a problem.
Old Mar 23, 2004 | 10:33 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Up here..a few inches in from the frame rail.
Old Mar 23, 2004 | 12:11 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Works for me, quick and easy.
Old Mar 23, 2004 | 10:04 PM
topdog's Avatar
Thanks guys.
I'll try mounting it behind the seat like you've said.
Let you know how it works out!!
Old Mar 24, 2004 | 07:05 AM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
i have my holley blue electric pump mounted inside the engine bay on the passenger side wheel well. WOW it is SO loud inside the car....i can here the thing buzzing all the time! it's very annoying. I even have a piece of rubber in between the pump and the well, but it does nothing. i need to relocate it to the back somewhere.
88IROC350TPI: what did you mount yours to? the side of the hatch well?
anyone have problems with hearing the pump vibrations?
Old Mar 24, 2004 | 11:30 AM
Car: '89 IROC-Z
Yup I just pulled up the carpet, drilled 2 holes and bolted 'er down. This same pump on my friends car was awfully loud but on my car its very very quiet due to my return line. With the return line the pump doesn't have to work as hard. With the motor on I can't hear the pump at all.
Old Mar 24, 2004 | 01:53 PM
xpndbl3's Avatar
Car: 1984 Z28
definitely hooking up the return line quiets these things down tremendously. mine was annoying to say the least until this year when i swtiched to a mallory 3 port with return line....i am MUCH happier now as well.
Old Mar 25, 2004 | 05:58 PM
Engine: carbed L98
how do you hook up a return line to a carb?
Old Mar 25, 2004 | 06:18 PM
Car: '89 IROC-Z
You need a return style fuel pressure regulator like the Mallory #4309
Old Aug 17, 2013 | 05:04 PM
tricky1's Avatar
Car: 1982 Pontiac Trans Am
Engine: Chevy 350 Vortec Roller
Transmission: Turbo 350
Axle/Gears: Moser 4.11
Re: Electric fuel pump mounting????
I have mine like 88IROC350TPI's on my 82 Trans Am. I'm working on an 82 Z28 Camaro and was looking to do something different. Wanted to weld some bungs into a new fuel tank and was looking for some ideas.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
