1989 350 tpi starting issue need help!
I have an 89 irocz 350tpi car. The car runs great and starts great when its cold. But after you run it for a while and cut it off it wont start back it will just crank. However you can spray a little bit of starting fluid in the intake and it will start right back up and will run as long as you want it to after it fires. It seems like the injectors are not wanting to fire on the intial restart but will work fine after one shot of starting fluid. Does anyone have any idea if it might be a sensor or what my issue might be?
mike
mike
Car: 1989 GTA
Engine: 5.7 w/Paxton
Re: 1989 350 tpi starting issue need help!
I swear you have echoed exactly my problem four or five months ago. In my case someone had put LT1 injectors in the car and the ECM did NOT like them and they were good injectors. They were 12ohm and these ECMs (1227165) are designed for 16ohm. So, I would check injectors and impedance. No cold start injector in 89.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Sanjay
Aug 12, 2015 03:41 PM
