Timing a 1987 LB9 Iroc
Old Dec 27, 2013 | 01:04 AM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
Not sure where the timing should be here's where it is currently. Doesn't seem right. All the stickers in my engine bay are gone (the car was stored by the PO outside for a decade), so that info is gone. If anyone could tell me the factory prescribed timing, that would be great. The car is an 87 iroc, 305 lb9, 700r4. Thanks for reading!
Old Dec 27, 2013 | 01:10 AM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
It needs to go up to atleast the big V (0*) if not one or two little v's past the big one in the opposite direction right now ur at 2* retarded
Wait I think ur at 6* retarded .. Not good ... U need to unplug the est wire then crank the car then set timing then turn car off then plug est wire back up
Old Dec 27, 2013 | 03:00 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Timing a 1987 LB9 Iroc
By the book, the timing should be set to 6* BTDC.
Old Dec 27, 2013 | 03:25 AM
Engine: 305 LB9
jesus, no wonder the exhaust has been smelling so bad. I've been working on this thing for like a year just assuming that the timing was still factory since I'm the 2nd owner and the PO didnt know anything about working on cars... That would explain a lot! Hope I didnt damage anything by running so many times with wacky timing. Thanks for the speedy responses!
Old Dec 27, 2013 | 05:03 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The ECM take control of engine timing after the engine rpm is higher than 600rpm.
For this reason a "Set Timing Connector" must be disconnected to disable the ECM control and allow setting the static baseline timing. The engine must be at normal operating temperature.
Don't forget to reconnect the connector after you're done.
Old Jan 2, 2014 | 04:03 PM
TFS355S10's Avatar
Car: Today? 98 GMC Sonoma
Engine: Seriously? The Sonoma has a TPI 305
Axle/Gears: 7.625/4.10
Just curious if 6 degrees is right for a 89 305 also?
Old Jan 2, 2014 | 06:56 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
the factory setting is 6 deg BTDC
Old Jan 2, 2014 | 10:41 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
It most likely is. Look for the underhood label to confirm. Hopefully the label is still there.
Old Jan 3, 2014 | 12:00 AM
TFS355S10's Avatar
That label could still be there. Hard to tell though. I haven't seen the hood for a couple years..... LOL
The motor in question is in my Sonoma. The emisions label on it says something like 2.2L??
I set it at 6 and seems to work.
Infested
May 22, 2018 11:56 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
kyleb24
Aug 15, 2015 08:24 AM
jahblah
Aug 12, 2015 05:54 PM
mustangman65_79
Aug 11, 2015 03:17 PM
