Maf to sd how do I mount ECM
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
My car is an 87 that came with the smallest ECM mount. I bought a mount from a 92 but it's much too long. What have yall been rigging up to mount the 7730 in an old car
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Maf to sd how do I mount ECM
The one on the left is the 90-92 it is the same length as the ones to the right 86-89 and the 85 that uses a pin inserted to the ecm to go into the speaker mount hole.
Car: 87 Iroc-Z
Engine: 305 tpi
Something must be weird about my car it's an 87 and came with the mount that inserts a pin into the top of the ECM. I have all three mounts pictured and the black one and 91-92 are longer, and the pin is a different shape and diameter. The older style pin was round where the new one is a cross. Maybe a new speaker mount will solve my problem
