Speed density
Car: 1988 under construction
Engine: 5.7 TPI
Transmission: 5 Speed
Axle/Gears: 3:73
Speed density
On a 1988 TPI if you go to a 1991 speed density do you have a problem with wipers from one harness to the other ?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Speed density
C100 is split into two parts, the chassis is not incorporated into the efi.
Elephantismo
Feb 13, 2019 12:51 AM
