what cam for bolt on l98 t.p.i (5.7)
Old Feb 7, 2014 | 10:32 PM
nickkaa1's Avatar
Car: 1990 iroc-z
Engine: 5.7 tpi
i have a 1990 irocz with 5.7 t.p.i has almost every bolt on expect for heads cam and still has stock intake (minor port work)
i have.....
larger injectors
performance chip
slp headers
edelbrock water pump
aftermarket radiator
ac delete
emissions delete
water meth injection
msd distributor
msd plug wires
ac delco sparkplugs
pullys
air foil
k&n intake
etc
etc
etc
i wanna decent cam that would fit for my stock heads and intake
LET ME KNOW WHAT YOU THINK! =]
Old Feb 7, 2014 | 10:59 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: what cam for bolt on l98 t.p.i (5.7)
Put the stock injectors back in. You dont need larger injectors with the stock motor. Besides you would need a new chip burned for the larger injectors to work. The stock cam is fine. Do you have a dual cat-back exhaust system? The car will run in the mid 13's@104mph.
Old Feb 7, 2014 | 11:10 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Crane 2032 cam.
Old Feb 7, 2014 | 11:14 PM
nickkaa1's Avatar
Car: 1990 iroc-z
Engine: 5.7 tpi
i have the chip burned for the injectors
also
3 inch exuast deleted cat to flowmasters mufflers in the back
does crane 2032 have a full kit?
Old Feb 7, 2014 | 11:16 PM
nickkaa1's Avatar
Car: 1990 iroc-z
Engine: 5.7 tpi
also note the motor is "tired" 160k and has seen NOS with alchol injection
Frozer!!!
Jan 19, 2024 04:55 PM
lt500r55
Sep 1, 2021 01:30 PM
LT1Formula
Aug 20, 2015 09:36 PM
anesthes
Aug 8, 2015 09:37 PM
