89 350 tpi code 12?
Old Feb 17, 2014 | 10:17 PM
msgZ28's Avatar
89 350 tpi code 12?
On Saturday I gave my "new" '89 IROC a good tune-up consisting of oil and filter, air filter, plugs, wires, cap, and rotor. Since then, my SES light has been on. The car is running good, a lot better than it did, so I'm not sure what is wrong. I jumped the proper diagnostic pins and got code 12 flashed to me. According to alldata and ATGO (Austinthirdgen board), there is no code 12 for a 350tpi. So...........what could be wrong? Nothing was left unplugged, and I tried to reset the code by leaving the battery negative unhooked for 5 min, but it still comes on. The only thing I can think of is that when I pulled the rotor, I did not mark where it was, but I eyeballed it since I had the new rotor in my hand and immediately replaced it. I know the wires are connected right, I labeled them on both ends and matched the new cap to the old cap (which was labeled before I unplugged anything).
Please HELP!!!!!!
Adam
Old Feb 17, 2014 | 11:24 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: 89 350 tpi code 12?
Your timing isn't off, so you should rule that one out. Even if you could somehow have moved cam and thus the crank, it wouldn't be off much and you probably wouldn't get a code. Code 12 is what it should flash, three times I believe, before it gives you the actual code. You should try to check for the code again just to see. Was your SES light on before you did the tune up?
Old Feb 18, 2014 | 12:22 AM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
code 1 2 is just verifying that your ecm is functional, if im not mistaken. Not an actual trouble code
Old Feb 18, 2014 | 03:48 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Code 12 is no DRP , this also will show three times when entering into diagnostic / field service mode koeo. If the mil is on constantly and you just get code 12s only sounds like you may have a bad ecm or ecm ground behind the drivers side cylinder head .
Old Feb 18, 2014 | 06:59 PM
msgZ28's Avatar
Okay, let me go ahead and put on my dunce cap. Following the advice here, I flashed the actual code, code 33 MAF. Well, let's open the hood and check it out......what's that connector hanging around under the intake hose? Oh look, the MAF came unplugged when I changed the air filter. Plugged it in and all better. At least it was something simple, right?
Old Feb 18, 2014 | 07:30 PM
thats awesome man! maf problems can be a pain!
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
