what sensors affect idle if bad
Subscribe
Feb 27, 2014 | 02:59 PM
car idles erratic but not all the time
what sensors can affect this
going to change them all out as not expensive
Reply 0
Feb 27, 2014 | 03:07 PM
O2 IAC tps CTS ICM
91' firebird .. 305 TBI .030 over , balanced bottom end , speed pro hyper flattops , 10.6:1 CR , all ARP rod bolts and main studs , melling HV oil pump , trick flow super 23 175cc heads, Howards HR 214/218@.050 .488/.495 lift on 114 LSA , full roller 1.6 RR = .520/.528 lift , summit dual plane intake port matched , shorty headers into 2.5" Y w full 3" flow master system and 3" cutout in front of axle , msd billet dizzy, 620cfm TBI , custom CAI , tubular adjustabke LCA pan hard , umi torque arm wonder bar , BMR trans cross member , COMP engineering SFC's, disc rear w 4.10's, drilled an slotted rotors, EBL flash , VRFPR, WBO2,
Reply 0
Feb 27, 2014 | 05:57 PM
Re: what sensors affect idle if bad
Quote: what sensors can affect this
Knowing what you own would help
https://www.thirdgen.org/forums/tech...formation.html
Reply 0
Feb 28, 2014 | 08:04 AM
done
Reply 0
Feb 28, 2014 | 08:40 PM
Pointless waste of time and $$ until you determine what actually is the problem
Pull the codes
https://www.thirdgen.org/forums/tech...s-dumbies.html
and report back any codes that show up
Reply 0
Subscribe
