fuel gaskets and vaccum lines?
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I have found these kits (9 O-rings) to replace the o-rings/gaskets in/near the fuel rails.
http://www.oreillyauto.com/site/c/de...2524&ppt=C0024
http://www.autozone.com/autozone/par...entifier=79645
Are there more seals as part of the fuel system in this area? If so, does anyone have any part numbers for a kit, or a website?
Also, all the vaccum lines snapped when I was removing my plenum and the runners due to age. Does anyone have part numbers or a website for replacements? I know everyone will say "fab your own." I'm just wondering if stock or near-storck replacements are available.
Thanks!
Bill
Thanks!
Bill
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1983 Z28
Engine: 385 Fastburn
Re: fuel gaskets and vaccum lines?
Thanks!
Bill
Thanks!
Bill
But in all seriousness, if you make your own (and by make I simply mean buy some 1/4" or 3/8" rubber fuel line and cut it to length) it will be cheaper and more durable. (the fuel line has thicker walls than what is typically sold as vacuum line).
vetteoz, thanks for the site.
RedLeader, I checked out RockAuto before posting and could not find vaccum lines. If you see them on there, could you send me a link?
I was consdering getting 1/4 or 3/8 silicone line, but I'm not sure which of the two sizes I need. What would be better, silicone line or fuel line?
Car: 1983 Z28
I couldn't find anything on there either, my bad.
It's up to you, I believe both will hold up about equally. The fuel line will have a thicker sidewall, but in terms of price I think it's all about the same.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
mdtoren
Aug 16, 2015 05:45 PM
