TPI for 600$?..
Car: 1991 Camaro RS
Engine: LO3
Re: TPI for 600$?..
http://sanantonio.craigslist.org/pts/4342737936.html
Forgot to post the ad for it, but yeah here it is. it looks okay to me but im still relatively new to this stuff so id like a little advice.
Transmission: T-5, TH350, T-5
Re: TPI for 600$?..
An unknown spec SBC out of a truck (see fan clutch) with a wiring harness that could need a lot of work to be correct in your car for 600! dollars.......no thanks. Unless you know for sure what the engine specs are (not just what the seller claims is in the engine) it's a lot of money for stuff that you may just end up having to change anyway. TPI stuff isn't that rare or expensive if you want to go that route. Avoid having to make more effort than necessary.
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: TPI for 600$?..
If you can wait a month, ill sell you my tpi intake, minus electronics, TB and fuel parts for $100 shipped.
-just letting you know
Those long tubes probably fit a truck too.
Car: 88 IROC-Z
Car: 1991 Camaro RS
Engine: LO3
Re: TPI for 600$?..
I guess im boned then lol, patience is key though, i learned that from having two past 3rd gens i mistreated, not this one though. 3rd times the charm for my new 3rd gen.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 87 Trans Am
Re: TPI for 600$?..
dont do that if you want there is a guy that lives on the other side of town as me that parts out 3rd and 4th gens and i was there today and he has 22tpi setups and proably sell you one alot cheaper shipped pm me and ill give you his # (going over to his house is like going to 3rd gen heaven)
Car: 88 iroc z28 t tops
Engine: 383tpi
Transmission: 700r4 2200 stall HD race pack
Axle/Gears: 342 detroit locker 10 bolt
Re: TPI for 600$?..
if i get a aftermarket for my stroker ill do u a lot better than that, and have even ported it a little bit and beed blasted the intake
Car: 1991 Camaro RS
Engine: LO3
Re: TPI for 600$?..
What would be the pros and cons on doing going with this option? sorry im a super noob, just starting my interest in these cars again since im a little older and have more funds available than i did a couple years ago with my past two 3rd gens.
Re: TPI for 600$?..
Pros- Easy to install. More displacement. WAY better heads. Easy to make more power later. Fuel pump swap NOT required
Cons- New intake manifold required. Computer needs a remap to make most of the new engine. TBI computer kind of a pain to remap. But thats easily fixed too http://www.dynamicefi.com/
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
