Restricted Return Line??
Old Apr 8, 2014 | 12:41 PM
tpi84stepside's Avatar
Would a restricted fuel return line cause a jumpy reading on a fuel pressure gauge? Needle is very jumpy with or without vacuum line hooked up. Pulsates along with the annoyingly loud ticking of the AFPR.
When the fuel pump primes, you can hear fuel "squirting sound". It runs great but sometimes at hard acceleration I can hear engine ping.
New Bosch3 injectors and AFPR
Fuel pressure key on: 43 (bleeds down in about a minute)
Spikes to 60 and drops when accelerating hard. Pulsating the whole time.
Old Apr 8, 2014 | 05:50 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Restricted Return Line??
when you changed your fuel pump, did you do away with the pulsator? your bleed down rate suggests something is leaking.as for engine ping what gas do you use? where is your timing set?
Old Apr 8, 2014 | 06:15 PM
I have an inline pump.. Timing is at 6*btdc. I use 89 octane..The pinging is rare. But when I was able to data log my blms were in the 150's.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
ericjon262
Sep 11, 2015 06:07 PM
TBRays98
Sep 6, 2015 05:05 PM
