355 tpi with t5
Old Apr 21, 2014 | 09:59 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
355 tpi with t5
Ok so i recently did a t5 conversion on my 88 firebird and im wondering if it is possible to get the tpi 350 to idle. Right now the idle on it is way to high 1100-1200 rpm exactly. Now i know i dont have a vac leak so im good there so my concern must be timing.
What is the correct way to set timing on the tpi setup. Wonder if i didnt do it right
Old Apr 21, 2014 | 11:17 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Key off unplug est connector. Start car adjust base timing. Tighten up distributor and dbl check the timing then shut car off and reconnect est. Of course if you still have a auto PROM that would make you have a higher idle too
Old Apr 22, 2014 | 11:15 AM
Engine: LR4 4.8
Re: 355 tpi with t5
Ok so this is were i went wrong should i also bypass the aldl port this should help not having the ecm trying to fight with the advancing and retarding right ???? I'll give this a try and see if i can get it to idle somewhat decent ill be happy with a 800-900 idle
Old Apr 22, 2014 | 11:22 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: 355 tpi with t5
did you change the chip? i believe the programmed idles are different due to the park/drive flag
Old Apr 22, 2014 | 11:45 AM
Car: 91 Trans Am
Engine: 355 TPI
Re: 355 tpi with t5
there is a write up on adjusting the timing here: https://www.thirdgen.org/settingtiming
IDK what you mean by bypassing the ALDL and IDK what that would give you.
Old Apr 22, 2014 | 01:00 PM
MadCelt's Avatar
Re: 355 tpi with t5
Yup. The man. and auto use different bins, and it's bigger than just the Park/drive flag. There are TCC settings, logr/higr settings, tables that depend on these... the MAN. bin pretty much adjusts tables based strictly on RPM alone, as the man trans has no switch to tell the ecm what gear it's in. He'll want to change his prom to a prom for a manual.
Old Apr 22, 2014 | 01:19 PM
92crimsonRS's Avatar
Car: 89 trans am GTA
Engine: 355
Re: 355 tpi with t5
what did you do with the wiring to the neutral safety switch? mine did the same and i just altered the wiring (dont remember what i did) and now it idles at 700 most of the time.
Old Apr 22, 2014 | 07:13 PM
Engine: LR4 4.8
Re: 355 tpi with t5
Im wondering the same i would love to get it at 700. I actually played around with it today and kinda got it alittle bit lower i think 900-950 idle its at now which is alot better then 1100-1200. Im gonna see if i can get it alittle bit more lower
Reddeath210
Oct 6, 2015 08:20 AM
JHX
Aug 29, 2015 02:30 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
