At wits end, hard start/no power under load, need help NOW!
Old Apr 22, 2014 | 08:47 PM
Gibson's Avatar
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
okay, so i get this 89 iroc-z (lb9/5speed) that been sitting since 2002 running after replacing the following:
injectors (now bosch 3's)
plugs
plug wires
cap
rotor
coil
maf
cts
fuel pump
fuel filter
o2 sensor
the TPS is fine and in adjustment
the iac is fine
the timing is spot on
the fuel pressure regulator is in great shape, looks like new
the ecm is flashing a code 33, both with the old and new mafs.
no vacuum leaks
it takes a long time cranking for it to want to fire off, and when it does fire, you have to hold the gas at ~2 grand. anymore, it'll die, any less, itll stall. when you do get it running, it makes lean pops threw the manifold sometimes, and after it warms up, it has like zero power under load.
need help asap. dont tell me to search, when theres 18 hours worth of reading and ever single thread tells me to replace everything ive just replaced, its not worth the time.
Old Apr 22, 2014 | 08:55 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: At wits end, hard start/no power under load, need help NOW!
What size injectors did you get? Also, is it possible you mixed up the firing order when doing the plug wires? I would check out the code 33 too. Heres a link for you.
http://chevythunder.com/maf_code_33.htm
Old Apr 22, 2014 | 09:14 PM
Gibson's Avatar
Engine: LB9
yellow top's from a 4.6l crown vic. ive checked the firing order like 18 times, and ive had other people check it at least 4, it 'should' be good' i just switched the maf relays around, and it fired right up, but wouldnt hold an idle. you would have to blip hte gas ever 2 seconds or so, it would go up to 1700 rpm, then slowly drop back to like 500 rpm, and try to die.
Old Apr 22, 2014 | 09:20 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I would go through that diagnosis chart for the code 33 I sent in the link as that possible could be you stalling out problem.
theshackle
Sep 17, 2020 08:26 AM
Amillionoh7
May 24, 2020 08:01 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
