MAF sensor- which one to choose?
Old May 5, 2014 | 03:15 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
I need a replacement MAF sensor, and found www.rockauto.com they will send it at a reasonable price to Europe.
But there are several choices:
2 new ones:
Airtec/Wells #5S2640
Standard Motor Products # MF5877N.
Both seems to be of a different design than stock, f.i. I see no heated wire ...
And three reman. ones:
A1 Cardone # 744712
AC Delco # 2133418
Cardone and AC Delco are the ones I know of, I don't know the rest.
Which one to choose for a stock engine?
Old May 5, 2014 | 03:37 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: MAF sensor- which one to choose?
My choice would be the Air/Tech Wells Maf (SU-145}. Reason it flows more air and the design is a internal film instead of the hot wire. I have been using the Wells Su-145 for 12 yrs now on my 350 TPI swap.
Do a search on this site for Wells SU-145 and you will have more then enough info to make this the Maf you order.
Attached Thumbnails MAF sensor- which one to choose?-engine-picture-right-side
Old May 6, 2014 | 07:09 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
2 new ones:
A1 Cardone # 744712
AC Delco # 2133418
beware the re-man ones, for this you should buy new. i reccomend a new one from "richporter" quite pricy,however well worth the investment
Old May 6, 2014 | 10:54 AM
What's the problem with the reman. ones?
Btw, since yesterday, Rockauto doesn't offer the Airtec/wells maf anymore...
So the only new one would be the Standard Motor Products one, but it is of a differend design...no heated wire, but on the other side, it is the least expensive Rockauto offer, even cheaper than the reman. ones....??
http://www.rockauto.com/catalog/more...853&cc=1251481
Old May 7, 2014 | 06:10 AM
Any thoughts or experiences with this new Standard Motor Products MAF sensor?
It is very inexpensive at least...
http://www.rockauto.com/catalog/moreinfo.php?pk=3779853
Old May 7, 2014 | 07:02 AM
It seems to me that the Wells SU 145, the Airtec 5S2640 and the Standard MF 5877N are all the same, right..?
Old May 7, 2014 | 02:26 PM
http://www.ebay.com/itm/271424405210...S:1123&vxp=mtr
They say Airtex and Wells are the same company, so this should be actually the same as a Wells SU 145..??
I asked about the sticker in the picture, but got a reply that it comes with a different sticker..??
Can anyone confirm that Airtex and Wells are the same?
Old May 7, 2014 | 06:06 PM
Car: 86 IROC
Engine: 5.0 TPI
this is the very LAST place you want to go cheep with. all the re-man ones come from CHINA. you need to buy a NEW one once and be done. OR you can go with the rest and actually spend more time and money than a new one costs.take it from me ,i bought 7 re-man ones . the last of which lasted all of 15 minutes. now i have a new one, and i couldnt be happier. sure they cost $$$ but they are worth the money
Old May 7, 2014 | 08:33 PM
DJP87Z28's Avatar
Ten years or more, Wells was involved in a patent dispute over the MAF film design and it may have been with Airtex. I know Wells Lost and did not make that design again. So Airtex may be the Wells old MAF, because SU-145 is the old part number and the price was also lower at that time. So I would give it a try.
Old May 7, 2014 | 11:21 PM
This is NOT a reman. one, but a brandnew MAF....
Old May 8, 2014 | 12:31 PM
I just bought this MAF...
Old May 8, 2014 | 01:03 PM
Car: 86 IROC
Engine: 5.0 TPI
good luck, after you get it back together .let us know how it went for you
Mark_ZZ3
May 24, 2018 01:02 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
