Injector connector?
Old May 17, 2014 | 09:54 AM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
Injector connector?
It's been a year since I've had the car together but I don't recollect the connector in the picture. On the passenger side, it's with the others, the iac, tps and temp sensor and looks like a injector connector, pink and brown wire. All nine injectors connectors present, accounted for and in the right place. Traced the wires back to the harness, doesn't look spliced in, what am I missing?
Old May 17, 2014 | 10:36 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Injector connector?
Its a intake tempature sensor located on the front of the tpi intake . Its square so it should be easy to locate
Old May 17, 2014 | 12:11 PM
brian p's Avatar
Car: 86 IROC
maybe not, from this thread (https://www.thirdgen.org/forums/tpi/...nsor-part.html) looks like it's a cold start switch?
Old May 17, 2014 | 04:43 PM
racerx520's Avatar
clicks onto your intake manifold in the front.
Old May 18, 2014 | 04:09 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
its the sensor in the lower corner, the brown one.
Old May 18, 2014 | 05:25 AM
brian p's Avatar
Car: 86 IROC
Now I get it. And the HSR won't be needing it so problem solved, thanks guys.
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
BAMiller
Sep 14, 2015 06:38 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
