Adjustable FPR recommendation
Old Jun 9, 2014 | 08:52 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
What kind/brand of adjustable fuel pressure regulator is everyone using? not sure which one to chose. Keep hearing good and bad about every brand.
Old Jun 9, 2014 | 10:03 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Adjustable FPR recommendation
Holley 512-501 works fine and is easy to adjust.
Old Jun 9, 2014 | 11:27 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
My Holley was nice looking and was easy to install. Sadly it is now a paper weight. It lasted roughly 6 months before causing erratic pressure fluctuation.
Old Jun 10, 2014 | 01:27 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
i Have holley and its working ok so far. had it for 2 months or so.
Old Jun 10, 2014 | 10:39 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I've had the Holley on for several years now with no issues. As stated, it is easy to adjust.
Old Jun 10, 2014 | 03:35 PM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
I have a Holley FPR I can adjust it with my thumb and index finger. No tools are needed
Old Jun 15, 2014 | 09:48 PM
GTAman's Avatar
went with the holley. Thanks for the input, guys!
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
Lmancha96
Sep 25, 2015 08:11 PM
