Camaro TPI Speed Density Swap.
Old Jun 11, 2014 | 02:59 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
About three months ago I decided to swap my Camaro to speed density TPI from Carb (the previous owner took of the TBI for some reason)
Anyways long story short Ive been slowly collecting all the parts and I am finally about done with the collecting process and am ready to get everything put together and be able to drive my car...
The old wiring harness/ecm, intake and, most of the smog equipment is out I am currently trying to put everything back together and have most of it done but of course I have ran into some road blocks.
The first one I have ran into is missing connections, the harness came from an 89 GTA, I dont have the connection that goes to the brake booster or the one that goes to the PS pump I dont see any cut wires so are these connections simply not on the earlier models?
I am also having some problems with the battery cables. not sure where the grounds go. This one is my fault I should have taken more pictures and notes.
Another thing. The person I purchased the harness from on here threw in an MSD Box, the 6A I believe. I have no idea how it works or how I should connect it0contemplating removing it all together; along with the box there is another MSD thing its a small square I believe It connects to the box.
What should I do with this thing?
Going to put some serious work into it tomorrow and try to figure this all out.
I appreciate any kind of insight you guys can offer on this I need all the help I can get tired of seeing the car just sit in my drive way.
Thank you.
-Luis
Old Jun 11, 2014 | 03:50 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Camaro TPI Speed Density Swap.
The harness you have is a MAF harness, not SD harness.
NBrehm
Aug 25, 2015 11:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
86Base
Aug 8, 2015 01:34 PM
