pcv question
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
pcv question
On the driver side is the pcv... Was thinking of putting a breather in place of the oil cap... But I saw on the passenger side its not a pcv but is connected to the intake... What does it do or could I put a breather on that side too...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: pcv question
You can cap the throttlebody port and use a vented breather. The passenger side pcv hose allows filtered air to enter into the crankcase.
Re: pcv question
I thank you all for all the help
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: pcv question
You should leave the pcv valve in the drivers side valve cover hooked up. If your going to install a push in breather, install it into the grommet on the passenger side vale cover.
Car: 89 IrocZ
Engine: L98-ish
Re: pcv question
To the OP...there is NO, none, zip, performance gain in what you want to do.
2QUIK4U
Sep 1, 2015 09:50 PM
