Bosch 111 Yellow Top OLM Check
Old Jul 2, 2014 | 03:26 PM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
What OLM readings should I be getting if the Bosch 111's (yellow tops) are good in my 305?
Old Jul 2, 2014 | 03:32 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Bosch 111 Yellow Top OLM Check
This says 10 to 16 ohms. But it's not Bosch spec specific. However, it stands to reason if the Bosch III injectors are a direct drop-n replacement the spec should still apply.
http://www.robietherobot.com/storm/f...ectorguide.htm
You might be able to do a search for the specs if you have the Bosch P/N.
Old Jul 2, 2014 | 03:44 PM
Car: 89 T/A
Engine: LB9
Thanks!
Steve78LT
Feb 24, 2016 12:15 AM
New2Chevy
Oct 4, 2015 11:27 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Firechicken86
Aug 12, 2015 10:07 PM
ZsTransAm
Aug 11, 2015 07:30 PM
