1989 tpi trans am. engine floods at crank
Old Aug 16, 2014 | 06:46 PM
BADBIRD89's Avatar
Is there a way i can test my purge valve, solenoid and the charcoal canister... what other sensor or emission component can cause it to run rich?
Car floods at start but runs fine after a few minutes.
My check engine light is not on.
Old Aug 16, 2014 | 07:26 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Re: 1989 tpi trans am. engine floods at crank
How do you know your flooding? Smell it at intake?
Old Aug 17, 2014 | 04:13 AM
BADBIRD89's Avatar
Found the problem... fuel pressure regulator.... hard starts at first, then would idle at 1000 rpm. Sound like there was a manifold leak or drowning. Kinda like a gargling sound...
Since i had replaced my fuel pump fuel tank and filter i havent installed the muffler... cuts off at the catalyc. The umburned fumes/fuel would go through the catalyc causing it to catch fire. ...problem solved though... i wish i wasnt so stuck on the purge and the canister. ..
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
marcusaw
Aug 10, 2015 08:13 AM
