TPI Throttle Body
Old Aug 25, 2014 | 07:46 PM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
TPI Throttle Body
Been searching the web trying to find a procedure/instruction on how to rebuild and/or port a TPI throttle body. Can anyone help?
Old Aug 26, 2014 | 07:26 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: TPI Throttle Body
I'm not sure it's worth it for a stock TB. Ever noticed that he shaft has pressed on levers on both sides? So you'd have to deal with that. Then.. is there even enough metal there to bore it out for larger butterflies? Seems like it would just make more sense to get a larger aftermarket one rather than trying to modify the stocker.
Old Aug 26, 2014 | 09:41 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
I think it's a bit more difficult if you don't have the right equipment to do the job right. There was a guy on ebay that was boring and rebuilding tb's a while back. I had him go through mine with no problems and it looks great. Others seemed to have a lot of issues getting their parts back. Either way it is possible and nice if you like the factory look. In the end it's just smarter to buy one off the message boards, not like they're rare or expensive anymore.
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
