Better heads for an LB9?
Old Aug 28, 2014 | 10:08 PM
92GTA's Avatar
So because I can't find a set of the old AFR 190 heads for the 305, I'm ready to pull the triggers on these babies:
http://www.summitracing.com/parts/tfs-30310007
I like them because they are center bolt, have the accessory bolt holes, are 50-state legal with a C.A.R.B. # (yes I'm in CA), etc. Basically because they are a direct replacement.
That said, I am going to be running a custom cam and a ProCharger. So.....are there any other heads I should consider which would be better or are these it right now?
Old Aug 28, 2014 | 11:10 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Better heads for an LB9?
They look like a good set of heads for a 305. The only thing I would consider if your going with a pro charger is methanol injection to safely run higher boost numbers. These heads have 56cc combustion chambers vs the factory's 58cc which would bump the CR over the factory 9:5 to 1. I would personally want the CR at 9:0 - 8:5 to 1 for a boosted application even though you could get away with something higher.
Old Sep 4, 2014 | 03:19 AM
thebandit50187's Avatar
Car: 92 Trans Am, 87 Formula
Engine: 305 soon to be TBI, 91 305 TPI swap
Axle/Gears: 10 bolt
i was going to suggest those 175 trick flows or i have heard gm fastburn heads with work
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
