timing suggestions
Old Sep 9, 2014 | 05:19 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
timing suggestions
LB9 1986 trans am...its really almost stock except ignition CAI,airfoil,no muffler(it fell off lol) 3" exhaust.. 160* thermostat. K&N filter...
But since the muffler fell off she runs a bit more richer... Should I start at 8-9* adv?
Old Sep 9, 2014 | 09:39 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: timing suggestions
No, find out why she's running rich
Old Sep 9, 2014 | 10:04 PM
camarofvr's Avatar
Car: 87 Camaro Z28
Engine: TPI 350 bored .030 over
Mine seems to like 10* with 72cc heads.
Old Sep 9, 2014 | 10:07 PM
happyhapka's Avatar
I think it has to do something with the muffler falling off.
happyhapka's Avatar
She's just rich at first until it warms up than is good
Old Sep 9, 2014 | 10:12 PM
camarofvr's Avatar
Car: 87 Camaro Z28
All gm's run rich at first startup.
Old Sep 9, 2014 | 10:16 PM
happyhapka's Avatar
Yes but she runs rough not like normal and I can smell she runs really rich but its weird.... She smells rich but my AFR short band says its right in stoich just way leaner until she warms up than its in normal range
Old Sep 9, 2014 | 10:19 PM
camarofvr's Avatar
Car: 87 Camaro Z28
No that's not normal. Check your plugs?
Old Sep 9, 2014 | 10:26 PM
happyhapka's Avatar
I have not yet..it started doing it about a week ago just haven't had time to take her out to my shop.... I was thinking plugs or O2 sensor... It has accel 8mm wires and cap and rotor... It came with the car when I naught her... I'm a msd guy so eventually that will be changed and wanted to change the plugs to Bosch+4 plugs for it.
Old Sep 9, 2014 | 10:29 PM
camarofvr's Avatar
Car: 87 Camaro Z28
I've never had good luck with accel.
Old Sep 9, 2014 | 11:31 PM
happyhapka's Avatar
Lol it is why I'm a msd guy....
Old Sep 10, 2014 | 02:14 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Rich, but way leaner...stoich...but not......think about things in a logical manner,,,smells rich, then yes it is...regardless of what your gauge says -note to self, may need ne gauge?
"all GM's run rich at start up"
How can I say this so as not to hurt any feelings...
BullShite
Old Sep 10, 2014 | 02:42 AM
camarofvr's Avatar
Car: 87 Camaro Z28
Yeah there's no such thing as "cold engine enrichment". Guess I should have said "some".
Old Sep 10, 2014 | 09:28 AM
happyhapka's Avatar
You don't think that when the muffler fell off that would cause it to run rich.. I say rich because it smells rich.. The guage is brand new auto meter... It just reads leaner at start and runs rough for a couple min. Than smooths out to normal and drives perfect.
Old Sep 10, 2014 | 09:30 AM
happyhapka's Avatar
Or maybe my inj?
Old Sep 10, 2014 | 09:39 AM
camarofvr's Avatar
Car: 87 Camaro Z28
No that won't affect how it burns fuel. Whenever I've had that kind of problem it was usually the plugs fouling until they were warmed up.
Old Sep 10, 2014 | 10:45 AM
happyhapka's Avatar
That would make sense... Thanks everyone.... I'll keep you all posted
Old Sep 10, 2014 | 12:38 PM
happyhapka's Avatar
What are some real ally good spark plugs these cars like? I usually is Bosch +4.
Old Sep 10, 2014 | 03:13 PM
camarofvr's Avatar
Car: 87 Camaro Z28
About the only kind I'll use are Bosch platinums but I was in a pinch one night and had to buy some autolight double platinums because I needed a shorter one to clear my headers and they work well. I've had good luck with both seems they don't foul as easy
Old Sep 11, 2014 | 10:08 AM
happyhapka's Avatar
Just found out that MSD makes spark plugs so I'm going to give them a try... What is the best gap for these engines?
Old Sep 11, 2014 | 10:16 AM
camarofvr's Avatar
Car: 87 Camaro Z28
I'd just leave them stock at.035 unless otherwise noticed.
theshackle
Sep 17, 2020 08:26 AM
Amillionoh7
May 24, 2020 08:01 AM
backtothe80s
Sep 5, 2015 12:39 AM
InfinityShade
Aug 22, 2015 08:00 PM
djmarch
Aug 9, 2015 05:27 PM
