87 Octane?
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
87 Octane?
So I accidentally put 13ish gallons of 87 octane into my 1991 L98. It's supposed to take premium fuel only. Should I just burn it off, or will I foul the engine and/or cause knocking?
I purchased some octane booster, but I should have added it to the tank BEFORE filling it up (so it mixes well, I guess). The other thing is that the octane booster doesn't give me a formula of how much I should add to the tank to achieve my desired octane rating. It just says "treats up to XX gallons."
Car: 1983 Z28
Engine: 385 Fastburn
Re: 87 Octane?
I agree, just burn it off. Car's made to run on premium will run on the cheaper stuff, they just aren't as happy about doing it. A bottle of 104 octane boost would help.
Car: 88GTA
Engine: 5.7TPI
Re: 87 Octane?
Really...Did I just read that? Just drive the car and don't worry about it. If you would of put Diesel in it, you'd have a problem.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 87 Octane?
Burn it off, if it really bothers you toss a bottle of octane booster in it
Justin92GTA
Aug 27, 2015 11:16 PM
