305 TPI running rich
Car: 1991 Pontiac Firebird Formula
Engine: 5.0 V8 TPI
Transmission: T-5 5 Speed
I bought my firebird about a year ago and the po said that they had had 24# injectors installed and now it runs rich. rich enough for smoke to come out the exhaust when starting the vehicle as well as when under a decent amount of load. I don't think that's normal even with the heavier fuel injectors and I'm curious if there is a good solution without buying different injectors.
I've considered adjusting the timing, but that scares me as the indicator at the harmonic balancer only goes to 12 degrees before TDC and I don't know how much I should adjust it anyway to allow greatest performance and safety. I have also noticed that when I get up in RPMs and let off the gas, I hear like a gurgling sound in the exhaust, don't know if that is in any way related.
I could really use a solution as I don't think the car will pass inspection without that fix (due to smoke coming from exhaust). I appreciate any assistance I can get with this.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 305 TPI running rich
Engine: 5.0 V8 TPI
yeah, I know the stock are 19# and the po increased it for performance. if possible, I would rather adjust something than pay to replace the injectors, if that makes sense. I know, I'm trying to be lazy and cheap, please forgive me.
Car: 86 IROC
Engine: 5.0 TPI
ok, we forgive you for being lazy and cheap. but the CARB wont. call south bay and get yourself some 19 lb hr injectors and move past this gaffe.
Engine: 5.0 V8 TPI
Carb as in carburetor? Or did you mean car? Because one of those I don't have.
Car: 86 IROC
Engine: 5.0 TPI
Engine: 5.0 V8 TPI
Very sorry. I need to update my profile. I don't live in california anymore. Louisiana just doesn't want to see smoke. They don't care so much about emissions.
rusty vango is right. 24's are a bit on the large side for the 305. I know you would rather not spend the money, however if we can help you in anyway, please don't hesitate to give us a shout.
Engine: 5.0 V8 TPI
well then, if I'm going to be forced to spend money, I would like to future proof things a little bit. another big reason I wanted to keep the 24# injectors was because I plan to do a swap and put a 357/383 in it. to my understanding the 24's aren't out of the scope for that engine. what size should I consider if I want something that's still viable after the swap? (I would like to not have to buy injectors twice, if possible) I know I'm trying to be cheap and I hate it, but I just got out the Marines and am a full time student so my income is a little limited.
Car: 86 IROC
Engine: 5.0 TPI
Engine: 5.0 V8 TPI
I hadn't thought of saving the ones that are on there already. I am not a smart man. Stupid question: will I see a loss of power when I drop to the 19# injectors?
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Engine: 5.0 V8 TPI
interesting point. I guess I'm just really worried. I'm an amateur and I don't want to break my toy.
but those fuel injectors have been in for at least 2 years.
but those fuel injectors have been in for at least 2 years. Joined: Jul 2003
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
but those fuel injectors have been in for at least 2 years. Thread Starter
Engine: 5.0 V8 TPI
quit bullying me! lol j/k. are you saying to do an oil change before the compression check because I just did an oil change (btw, apparently K&N 2002 is not a perfect fit for my car, Mobile 1 M1-111 or whatever fit much better, K&N leaked real bad on this last oil change I did)
Car: 86 IROC
Engine: 5.0 TPI
Engine: 5.0 V8 TPI
Hmm. How about 302 and power? Wooh Ford! Haha. I kid, don't shoot me please. MPGs were never much of a concern to me, if they were that important I would have bought a civic.
Car: 86 IROC
Engine: 5.0 TPI
