Whose using it? TPI Vortec base rear coolant crossover
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
The Vortec TPI intake base has a rear coolant crossover passage, and a 1/8" NPT port. Is anyone using it? Does anyone have a picture of theirs?
Since I don't have room for a spacer at the thermostat, I figure any unused port at the front will work (9th/CSI deleted leaves at least one available).
Transmission: Pro-built 700R4
Re: Whose using it? TPI Vortec base rear coolant crossover
What are the benefits of using that passage?
Car: 87 IROC
Engine: L31 350
Coolant circulation from the back of the heads. It is supposed to help prevent hot spots in the rear. If you believe, or need that kind of thing.
https://www.thirdgen.org/forums/fabr...ines-rear.html
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
