tpi/holley stealth ram engine help
Hey guys I have a 91 Camaro that I'm building I have a 383 stroker and a set of brodix spec heads. I was wanting to put the holley stealth on it and run the LT-4 hotcam in it what do you think? will the set up that I'm wanting to run work? I am also running an automatic
. I'm looking for 400+ out of the car. thanks for any help.
. I'm looking for 400+ out of the car. thanks for any help. Joined: Nov 2008
Transmission: T-5, TH350, T-5
Re: tpi/holley stealth ram engine help
Not sure what your looking for? Will a stealth ram work? Yes. It'll easly support 400hp on a 383. Not sure why TGO would need to answer that. No info on your computer plans. Not a whole lot to "brodix spec heads" to know what you're working with. No part #. No port volumes. No flow #s. No compression #s or chamber sizes. Leaves the forum's experts in the dark. I can't personally tell you if the cam is the best choice. I don't see anything wrong with it though. Could be a little tame. You have an automatic but which one? 700r4? TH350? What gears and axle sre you using? Give some details and hopefully a real expert (not me) will be able to help. They get tired of hunting for information.
9192camaro
16
Feb 3, 2019 12:21 AM
L98GTA87
Aug 11, 2015 06:55 PM
