Edelbrock TES y-pipe?
Car: 1985 Camaro IROC-Z
Engine: LB9
Axle/Gears: 10 Bolt, 3.42 gears
I picked up a set of Edelbrock TES headers the other day for really cheap. I know Edelbrock doesn't make headers anymore, but is there another y-pipe that can be used for these? Will they bolt to the stock y-pipe? Is my best bet just to get a custom y-pipe made?
Re: Edelbrock TES y-pipe?
Your in luck I have a Y pipe for the edelbrock shorty headers like new just need one of the rings for the d.side i believe.
I had a custom one and the original one the guy that bought them took the custom since it was made for true duals.
Car: 6.2L pontiac firebird
Engine: 383 stroker
Axle/Gears: 373
Hey just wondering if you still have that Tes y pipe for the edelbrock shorty headers I'm in dire need of one I bought the headers years ago but don't know why I didn't buy the y pipe to install them
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I make these if your interested.
Check to see if it matches, they made several models.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The eddy y-pipe design was crud where the two pipes combined.
The metal was very poor quality and usually rusted and pitted quickly.
Dons look much much better than the original design IMO.
Car: 82 Camaro Sports coupe
Engine: 350 V8
who has the y-pipe for the edelbrock tes heads? I need one too. I just bought the edelbrock 6875 header for my 82 Camaro thought I could use my old y-pipe but they don't fit
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
I am out of flanges right now, I will have more soon.
Car: 1987 GTA & 1984 Trans Am
Engine: 383 stroker TPI
Dyno Don:
I believe I have the same type Edlebrock headers.
Bob
Bob
Car: '89 GTA Convertible
Axle/Gears: 3:27
I have a 1989 Firebird 5.7 with a set of shorty Edelbrock's, identified only by an Edelbrock metal id tag riveted to the top of the #2 tube along side the valve cover. I need to replace my y-pipe but am not positive it is the same as Dyno Don's. Looks real close, i.e 2 bolt flanges and 3 inch at the y. Mine uses 2.5 inch gaskets. Inlet pipe on the driver side of mine does not appear to have quite the same angle as the one in the picture above though. Could be misjudging it... ?
Edit: It looks like per this thread - https://www.thirdgen.org/forums/engi...k-65930-a.html , it is built specifically for the Edelbrock headers with single cat outlet.
Engine: LB9
Car: 92 RS
Thank you
blackztpi
Aftermarket Product Review
Jun 4, 2003 10:01 PM
