are there any aftermarket rockers that will fit under factory valve covers ?
Old 04-10-2015, 10:21 PM
ray jr's Avatar
have a 87 350 iroc and would like to keep the factory valve covers but would also like to add some aftermarket rockers .. are there any rockers that will fit under the factory center bolt valve covers ? roller tip or full roller really doesnt matter to me ..
Old 04-10-2015, 11:47 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Re: are there any aftermarket rockers that will fit under factory valve covers ?
COMP 1018 rockers fit under my stock centerbolt valve covers with no clearance issues whatsoever. Note that these rockers are not self aligning.
http://www.jegs.com/i/COMP+Cams/249/1018-16/10002/-1
Old 04-11-2015, 09:31 AM
COTM Editor (Retired)
Linson's Avatar
Car: 89 Formula 350, TTA
i think just about any 1.5 ratio self aligning rocker arm will fit under factory valve covers. I have Jegs 1.5 ratio self-aligning roller rockers under the factory valve covers on my '89 Formula 350.
if you want 1.6 ratio, then it might be only certain ones that will fit.
Old 04-11-2015, 10:50 PM
T-rock's Avatar
Car: 1987 camaro iroc
Transmission: 5 speed borg warner
Axle/Gears: 3.45
Scorpion makes a set of self aligning ones that will fit
NBrehm
08-25-2015 11:49 PM
db057
08-22-2015 08:17 PM
1985chevydude
08-20-2015 12:29 AM
blackd-out z28
08-15-2015 08:18 PM
mustangman65_79
08-08-2015 01:18 AM
Quick Reply: are there any aftermarket rockers that will fit under factory valve covers ?
