Tpi throttle body
Car: 86 IROC-Z
Engine: 355
Tpi throttle body
Hey guys. I'm Looking at aftermarket throttle bodies. My stock 48mm is a little sticky off idle sometimes. I've done enough mods to justify going with a 52mm setup. I like the price on the summit racing TPI throttle body, but can't find much on here about them.
(I may have missed some good posts, I apologize if I did) Anyone using one of them? How do you like it? Should I spend a bit more and go with a Holley? Thanks for any input/opinions!
Car: 1989 Firebird Trans Am
Engine: 355
Re: Tpi throttle body
Check aftermarket product review. I wouldn't get one personally because they really don't do much at all. I would disassemble it and clean it with carb cleaner, buy a gasket set for it and rebuild it. Good as new.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Get the BBK one or don't bother. The summit, professional products, Chinese crap isn't worth it. I bought a brand new PP throttle body and it was junk. Thankfully summit took it back.
Engine: 355
BBK and Holley both make great products. Summit is probably crap. Never had one personally. You might have some luck just polishing and porting the inside of the throttle body. Obviously don't sand/ port around the flaps, but polish really well.
Car: 86 IROC-Z
Engine: 355
Thanks for the replies! I have been doing a little research and talked to a few people and ended up ordering a BBK 52mm unit today.
I ordered it from them directly, they were very cool, and gave me a great deal! We'll see how it turns out.
thanks again
thanks again
mdtoren
Aug 16, 2015 05:45 PM
