TPI Swap not running.
So I did a tpi swap on my 1969 327. Its currently wont start or idle, It seems like it isn't getting fuel past the injectors. I am getting 41psi at the rail, I have spark. it will start for a moment on start spray but like I don't think the injectors are spraying. Custom prom I burned it myself I will attach it if you want to look and see if I missed something on it. By the way the fuel pump is running so I don't think its a vats issue. Should i just pop the fuel rail/injectors off and see if they are spraying?
Re: TPI Swap not running.
whats the best way to test that? I was thinking to just pop the rail off with them and try turning it over. btw I did test them with an ohm meter before I put this in the truck. they all had good ohm readings.
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
A noid light will tell you if they are getting the system to fire (ground trigger from ECM).
Most likely culprits are bad/not enough grounds on the ECM and engine, bad ignition control module, bad ECM, or no signal from ECM to ignition control module. Check continuity between the top of your plenum and the chassis, it should be close to or below 1 ohm.
This problem rears up from time to time in the forums, I did a basic google search and came up with tons of threads on Thirdgen about it. Also;
http://www.camaros.net/forums/showthread.php?t=153617
If you have someone that can crank the engine for you you can also listen for the injectors firing. Put a screwdriver tip on the injector and your ear against the end of the handle while they crank it. You should hear the injector cycling if it's firing. It will be a loud fast clicking.
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Ok so I did some tests today. I have a 0 ohm reading from the top of the motor to the fire wall. I used a noid light and got nothing. I do have 12+ to the injectors. I attached my BIN if anyone cares to take a look. Now I programmed out vats unless somehow I missed it, now the blue vats wire, does it need 12+ because right now I don't have it wired into anything.
Also could it be the park/neutral? I havent wired that in to anything yet. If so do I have to wire it in to the clutch pedal?
Sounds like either your ECM is not sending the trigger to ground the injectors, or the ignition module isn't triggering the ECM. Follow the link I sent earlier to troubleshoot both. Rule out the simple stuff before delving into troubleshooting VATS.
-Ive tested with all the injectors unplugged with just the noid light and got nothing so it is not a shorted injector.
-I have 3 power feeds to my ecu all of which are good.They are as follows pin G,B and F on c207(let me know if I am supposed to have more.)
How do I test the ignition control? I do have spark. all of the ECU grounds are to the engine block correct? I think all my grounds are good.
Car: 83 Malibu/86 C10
Transmission: T5/SM465
Axle/Gears: 7.625/3.73 - 8.5/2.73
If it's a VATS issue, thats simple to check in the file. It's either on or off, for a swap it should be OFF. Had this same issue when I first tried to start my swap, forgot to turn off VATS
Can't remember, but if you're using Tunerpro it's a checkbox for VATS, no need to really get into the code.
Following this flow chart I think I have a bad ICM http://www.chevythunder.com/est_code_42.htm
So i have a reading of 230ish ohms on wire c8 white and 12.4 on c7 using c7 as a ground. disconnect the ICM and goes to 0 volts.
I am going to swap out for another dissy at the junk yard(he warranties his parts) and this on is from the yard came with the whole tpi system.
Can someone explain why I still have spark with the ICM being bad? I thought when that goes out on these electronic controlled dissy that they stop having spark. I am completely new to EFI before a month ago I figured EFI and witchcraft were the same thing. I understand points/carb very well but this stuff isnt as easy for me.
Transmission: 2004r
Transmission: 2004r
Garnerm, which ecm are you running? MAF or SD. At this point, you may need to do a pinout and check each pin in the ecm harness and verify that they terminate where the circuit diagram says.
Transmission: 2004r
Garnerm, in post #10 you mentioned that you have three power feeds going to the ecm via connector c207. My swap is maf, I'm not too familier with SD, but I have circuit diagrams for both. Looking at the diagram for SD, there are three power feeds to the ecm. BA6, in the 24 pin connector, is 12V+ ignition feed. That one is probably being feed thru the c207 connector. There are also two battery feeds, hot at all times. BC16 and BB1, these two may not be fed from connector c207, but wired in the main harness. That's the way it was in my maf swap. I suggest you check the power feeds going to the ecm by back probing the ecm connectors. BC16 is in the 32 pin black connector and BB1 is in the 24 pin black connector.
I solved it! with help from others... My eprom was not compatible. the chip itself so I ordered SST 27sf512 chips and they were $5 cheaper than the original one I bought. burned a new chip and it lives!
theshackle
Mar 5, 2017 06:37 PM
Sanjay
Aug 12, 2015 03:41 PM
