Sensors on the front of the intake manifold
Old May 25, 2015 | 06:42 PM
86IROC112's Avatar
Car: 1986 IROC Z
Hi guys,
I am re-installing the TPI onto my car cuz the guy I bought it from put a carb on it. Anyway, there are two plug in sensors on the front of the intake manifold. One must be the coolant temperature sender, what is the other one?
Anyone know where I can find an exploded view of all the components?
Thanks!
Old May 25, 2015 | 07:21 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Sensors on the front of the intake manifold
One is the cold start injector switch. the other is coolant temp. http://chevythunder.com/fuel%20injec....%20pg%20B.htm
Old May 25, 2015 | 07:52 PM
86IROC112's Avatar
Car: 1986 IROC Z
Thanks! I can only find one plug that fits those fittings. According to the color codes on the wires I have the coolant temp plug but I can't find the other. I don't think the guy I bought the car from cut or removed any of the plugs. I figured it would be in the same mass if wires and plugs on the passenger side.????
Old May 26, 2015 | 08:30 PM
Irocblast's Avatar
Car: 1987Iroc
Engine: 5.7
Cold start injector temp switch if older, not sure when they did away with 9th injector what year is the car?
Old May 26, 2015 | 09:59 PM
86IROC112's Avatar
Car: 1986 IROC Z
It's an '86. It has the cold start injector but I can't find the plug that goes to the sensor..??
Old Jun 4, 2015 | 06:52 PM
86IROC112's Avatar
Car: 1986 IROC Z
OK, I've got it and according to the color of the wires in the wiring diagram I found the wires that plug into it. Only problem is the connector does not match. The wires which match the colors in the wiring diagrams, and are in the perfect location for the cold start injection switch, have what appears to be a fuel injector type connector, not a match for the switch?? The connector looks stock and original. Could it have the wrong sender/switch installed on the manifold????
Old Jun 4, 2015 | 07:38 PM
Those are your connections? I think you have it right, are you sure they don't connect?
Old Jun 4, 2015 | 07:50 PM
86IROC112's Avatar
Car: 1986 IROC Z
Someone has installed the wrong switch. It has two temp sender switches. Great....Of course that part has been discontinued...The search goes on...
Thanks!
Old Jun 4, 2015 | 08:10 PM
Rock Auto shows it....EGT4 and Napa.....TS7001
Old Jun 4, 2015 | 08:15 PM
86IROC112's Avatar
Car: 1986 IROC Z
[QUOTE=aliceempire;5925084]Rock Auto shows it....EGT4 and Napa.....TS7001[/QUOTE
Sweet! I have a NAPA just up the road....Thanks
Old Sep 3, 2018 | 08:32 AM
mcb55-210's Avatar
Sorry for high jacking this post, but I am in the process of rewiring my '85 TPI after a long delay of 15 years. My Cold Start Switch and Coolant Temp Sensor are located as in the picture above, but in the wiring diagram it shows them as reversed in location. Unfortunately I didn't take any pictures before disassembly, and now all these years later I want to make sure I have it right. Even Chevythunder.com has them the opposite of mine and the above picture.
Can anyone enlighten me?
Mike
I just saw one on eBay that has the sensors as pictured above....I don't have a factory manual to see what it shows, so will wait for guidance!!!!
Old Sep 3, 2018 | 04:38 PM
Mike
I don't believe it makes any difference as they are both going into the same coolant feed. The wires being able to reach would be my only concern. I'm willing to bet the factory might not have put them in the same places
Old Sep 3, 2018 | 08:20 PM
Drew's Avatar
The pic is how they're supposed to be, but yeah it really doesn't make a bit of difference.
Jake_92RS
Jan 28, 2020 10:37 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
