EGR and it's solenoid..?
Car: 1986 IROC Z
Trying to get this car going and realized I don't have an EGR solenoid and understand they aren't made anymore. I do not intend to install the AIR system when I put it all back together.
If I don't reinstall the AIR system will I need the EGR and the solenoid all hooked up or can I just block off the EGR valve?
Thanks!
Thanks!
Car: 1987Iroc
Engine: 5.7
Re: EGR and it's solenoid..?
You will need the solenoid connected or will get a check engine light. You could get PROM burned for it with EGR delete and other parameters diasabled or changed There is a gentleman on this forum that does that work. Seems to get good reviews I believe he goes by " Tuned Performance" I think they may be available after market but do not quote me.
Car: 1986 IROC Z
OK, so it will not effect the performance of the engine, just give me the check engine light? My first goal is to get it running then I can smooth out all the bumps..
Transmission: T-5, TH350, T-5
I may cause running issues. The calibration is expecting inert exhaust gas to be added to the mix, with the egr doing nothing the chambers aren't getting that inert gas. I don't know how significant it will be with your car but my SD tpi wasn't happy at freeway cruises with the egr solenoid failing.
Car: 1986 IROC Z
Car: 86 Trans Am WS6
Engine: 383 stroker
If you look around there's a thread on this site about a certain cadillacs egr solenoid working for our cars. I would look into it and try to track one down or find a thirdgen at a junkyard before getting the tune to remove code 32 and putting a block off plate on.
My car ran horribly when the EGR went. I would be hesitant to remove it permanently.
Edit: I believe the Cadillac with the similar egr solenoid is a 1994 Cadillac Deville 4.9l 8cyl.
Car: 1986 IROC Z
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Car: 1986 IROC Z
If you do switch to a Caddilac solenoid you will have to make a connector or splice the correct plug into the harness. It changes from a weather pack connector to a metripack connector.
Engine: 383 stroker
I tried looking for the right connector but couldn't find a part number, would be good info to have one in this thread for anyone else wanting to switch to the Cadillac solenoid
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
I was able to use an egr solenoid from an LT1. They still make those. If nothing else see if you can find one at a junk yard.
The connectors and such had a write up a long time ago.
http://s9.zetaboards.com/nythirdgen/...7236770/1/#new
HoosierinWA
Oct 7, 2015 10:15 AM
